Hello everyone,i'm the owner of a 508 RXH Hybrid4 and the nightmares never ends whit this car.
while taking of from an intersection,like I normally do,the car completly went crazy going into limp mode and giving me the message(Parking brake fault,stop the veicle immediatly). Car is dead and i can't start it in any mode so I take it home whit a trailer,with a lot of truble since the EPB was stuck on an I wasen't able to de-engage it.(1600 EUR quote just for the EPB assembly at the dealer,absolutly crazy. )
At home I've compleatly disassembled the EPB unit.The small elettric Motor is ok,all the palstic gears are ok,no broken cable,nothing !!
So this is were the fun begins. If I try to turn on the car,it won't let me.but if I prerss the Button for the parking brake I can hear it starting to engage then immediatly stopping and teturning to the 'zero' position.BUT,if I keep the button pressed the parking brake will compleatly engage at 100% and stay at 100% if I'Il keep the button pressed.As soon as I release it, it fastly return to the 'zero' position (disengaged).
This tells me thah the meccanical part of the system is functioning and most likely it's a problem with the EPB ECU(?).
BUT,if I try to clear the code with a ODB2 scanner and the CarScannerOBD2 app (I bought the pro version),NONE OF THE CODE ERASES. I can clearly see al the DTC codes , select them and erase them one by one or all tougether but if I turn the ignition off then on angain is like i didn't do nothing.
I tried to create a fault on my mom Peugeot 108 by unplugging the O2 sensor and I was able to see the code,delete it, and everithing was normal afrer so the app and the scanner work.
I'm thinking that the EPB is just a cause related to a faulty ECU?
P.S.:I don't have diagbox so I have no other method to connect to the car .
Thanks for any help ,I'm loosing it.
508 RXH EPB FAULT/CAN'T CLEAR ANY CODE?
- x 1496
GianlucaPilot
- x 3
Re: 508 RXH EPB FAULT/CAN'T CLEAR ANY CODE?
This is the list of the code, but at one point the battery went flat so I think it's normal to have a lot of this. I can't clear them because it won't let me.
Car Scanner ELM OBD2
Version: 1.105.1/1.105.1/iOS
DTC report
Connection profile: Peugeot OBD-II / EOBDDate: 24/03/2024 16:45:46
OBD-IIOBD-II
DTCs: 8
U1218 [0xD218]
Stato: Errore in sospeso presente
U1187 [0xD187]
U1105 [0xD105]
U1113 [0xD113]
U0293 [0xC293]
Lost communication with hybrid powertrain control module
U2118 [0xE118]
P0215 [0x0215]
Fuel shut-off solenoid - circuit malfunction
U2000 [0xE000]
Audio Rear Control Unit is Not Responding
Unità di controllo motore#1Unità di controllo motore#1
DTCs: 8
U1218 [0xD218]
U1187 [0xD187]
U1105 [0xD105]
U1113 [0xD113]
U0293 [0xC293]
U2118 [0xE118]
P0215 [0x0215]
U2000 [0xE000]
Centralina di trasmissione#1
Nessun codice errore (DTC) trovato.
Unità di controllo motore#3Unità di controllo motore#3
DTCs: 8
U1218 [0xD218]
Stato: Il test è inibito da altri DTC, Convalidato e archiviato nella memoria non volatile
U1187 [0xD187]
U1105 [0xD105]
U1113 [0xD113]
U0293 [0xC293]
U2118 [0xE118]
P0215 [0x0215]
U2000 [0xE000]
Centralina di trasmissione#3 / BSI
Unità di controllo motore#4Unità di controllo motore#4
DTCs: 8
U1218 [0xD218]
U1187 [0xD187]
U1105 [0xD105]
U1113 [0xD113]
U0293 [0xC293]
U2118 [0xE118]
P0215 [0x0215]
U2000 [0xE000]
Power steeringPower steering
DTCs: 4
U1305 [0xD305]
C1408 [0x5408]
U1308 [0xD308]
U1108 [0xD108]
DTC report
OBD-IIOBD-II
DTCs: 8
U1218 [0xD218]
U1187 [0xD187]
U1105 [0xD105]
U1113 [0xD113]
U0293 [0xC293]
U2118 [0xE118]
P0215 [0x0215]
U2000 [0xE000]
DTCs: 8
U1218 [0xD218]
U1187 [0xD187]
U1105 [0xD105]
U1113 [0xD113]
U0293 [0xC293]
U2118 [0xE118]
P0215 [0x0215]
U2000 [0xE000]
DTCs: 8
U1218 [0xD218]
U1187 [0xD187]
U1105 [0xD105]
U1113 [0xD113]
U0293 [0xC293]
U2118 [0xE118]
P0215 [0x0215]
U2000 [0xE000]
DTCs: 8
U1218 [0xD218]
U1187 [0xD187]
U1105 [0xD105]
U1113 [0xD113]
U0293 [0xC293]
U2118 [0xE118]
P0215 [0x0215]
U2000 [0xE000]
DTCs: 4
U1305 [0xD305]
C1408 [0x5408]
U1308 [0xD308]
U1108 [0xD108]
vic678
Hello Gianluca, were you able to fix the car ?
