The power steering pump stopped working while i was driving and when i turned of the engine and then turned it on again the problem solved. But the problem keeps recurring. I need to know why?
I did these actions:
I checked the fuse box
reconnected the earth wire.
I used a tie rap to fix the plug of the pump.
I still have the same problem
Power steering pump problem
- x 6946
Re: Power steering pump problem
We'll need the VIN to determine the system you have fitted as they are different. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
ebrahimsalama
- x 6946
Ok so you have an electro pump. These are operated directly from the battery, so if you have a weak battery there may not be enough power getting to the power steering pump.
How old is the battery? If it's anything older than 5 years it needs changing most likely, because as it ages, it looses capacity so can't store as much energy as a new one.
- x 1056
Are you also getting a good voltage output from the alternator at the battery & also getting the same voltage at the main pump connector?
With the engine running & the pump not working if you tap the metal part of the pump casing with a mallet does it start working again?
ebrahimsalama
Voltage of alternator is 14.4v
Voltage of battery is 12.7 v
I bought battery 2 years ago
ebrahimsalama
Today it stopped working completely. I did everything i can but there are no results.
I think i have to replace the pump
ebrahimsalama
Thank you for helping me
The problem solved. It was the plug.
Thank you again
Thank you again
