Xantia sinking on starting (TD 1995)
johntaylor
Unread post by johntaylor »
About ten seconds after starting the rear starts to drop, the front appears to rise, then the pump catches up and it rises and levels OK.
I fitted a new anti sink sphere. Is it the accumulator sphere at fault? All responses appreciated. Also my tachometer sometimes sticks at 50mph and stays there until I whack the dashboard hard!
John
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
I think the time has come for a new accumulator sphere.
bernie
Unread post by bernie »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by johntaylor</i>
John
Tachometer (revcounter) and 50mph[?][?][?]
Is it the tachometer or the speedometer that sticks?
Either one it's probably mechanically sticking so a strip and a clean will do I'd say[:)]
hubcap
Unread post by hubcap »
I have had that problem with my xantia.it is an electronic device and had dry solder joints on the panel.
