Citroen C5 x7 NG4 stereo
MarcinS
Hi all
I’m hoping there’s someone who knows this stereos and can help , the problem with it is it turns on fine however there’s no sound and it keeps resetting itself just before it does it I noticed the sos button is flashing , and it will keep resetting itself for about 30-40 minutes and then it will play fine for rest of the journey I have scan it with Lexia and autel both coming up with code F088 lost communication with cd changer however this car doesn’t have one fitted as I looked everywhere
- x 6945
Re: Citroen C5 x7 NG4 stereo
Hi, let me have the VIN and I'll confirm if this is the case or not. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
MarcinS
Hi the vin number is VF7**************[VIN obfuscated, can be read by forum staff]
- x 6945
Ok, so you don't have the CD changer fitted at factory.
Have you replaced or changed anything including the NG4?
Have you used Lexia / Diagbox to change anything?
Has this NG4 come from another vehicle?
MarcinS
Nothing was changed as far as I know I bought the car with few issues while ago with intention of putting back on the road so I flexed the wiring loom for rear parking sensors and Egr valve but I can’t figure out why the stereo is playing up like this
- x 6945
The SOS button is part of the services module, which is essentially a telematic unit for providing geolocation services in an emergency and emergency calling in the even of an airbag activation.
If the SOS is flashing, this likely means the battery needs replacing (as it will be 14 years old now). As the services module is linked directly to the NG4 it may be a reason why the unit is playing up. May be worth checking with the dealer to confirm and check replacement cost.
MarcinS
I will get a new one ordered but would this cause the nh4 unit to have this symptoms?
- x 6945
Well where the services module is fitted, it does control the microphone and routes info to the NG4, then you have the equaliser Amp too to factor in.
I can't say that why will resolve the issue, but it is one factor.
It's possible the NG4 has or is starting to suffer from a Hard Drive Failure given the age. I replaced mine with a CF card upgrade for which I put a guide on this sub-forum.
You should be able to get some sort of fault codes or look at live data - if you use Diagbox - I can't speak for Autel though.
MarcinS
I will plug the diagbox and see if I can get any more info
- x 6945
When you run a global scan, it will start interrogating the NG4 and you may hear it kick into life for a second, but after that, see what, if any faults you get.
You can also select the NG4 ECU from the list of ECUs and from there, can select some live tests to check button pushes and various other things.
MarcinS
Yeah I’ve done that and all buttons work however no sound coming through the speakers but after 30-40 minutes it does start to play and it will work fine until I switch the engine off and lock the car
- x 6945
Is this one particular music source or everything? USB for MP3, DVD, Hard Drive Jukebox, Radio?
MarcinS
Everything regardless what you want to play you won’t get any sound at all for about 30-40 minutes and in this period of time it will reset it’s left several times
- x 6945
Ok, sounds suspiciously like the hard drive is on the way out! Constant resetting is the first sign of imminent failure.
I have the firmware should you need this, which is the last edition released. It can be used to reinstall the operating system. Let me know if you need this. Automotive quality drives are very hard to get these days.
MarcinS
So how do I go about fixing this issue ? I’m quite handy with electronics as I do remapping and mechanics just never had this issue before so if you got any advice or guide it would be hugely appreciated and yeah I could do with the firmware if you don’t mind
