Hi
[?]Does anyone know where I can get info on the ecu pin connections for an XM 2.0i XU10J2 circa 92/93??? I need the info to wire up an LPG conversion. The pins I need are - Lambda, engine speed, and throttle position. Any information, however sketchy, gratefully received.
ECU Wiring Diagram
wilsonkrg
Ah Google is wonderful. Apparently the Peugeot 605 shares the same engine as the XM. So try this link to get an ECU circuit diagram.
http://peugeot.mainspot.net/wiring605/index.shtml
Good Luck
Ken W (Australia)
Good Luck
Ken W (Australia)
dopscribe
