2009 Citroen c5 x7 suspension faulty
Jameswhereisit
Unread post by Jameswhereisit »
Hi all I wonder if anyone can help me. Over the past week I have had a warning light come up on the dash saying suspension faulty service, then it goes away after a few seconds. I have checked both front and back for any kind of leaks or damaged or broken sensors. I have even checked the ride height sensor and they all seem to be fine. Any suggestions as to what it could be?
( I have also checked all fuses for the suspension too)
Reason: Moved to the Citroen Forum
x 6955
Re: 2009 Citroen c5 x7 suspension faulty
You'll need to get it on Lexia or Diagbox. It's impossible for you to determine whether a height sensor is faulty or not just by looking at it.
There are a myriad of fault codes pertaining to the suspension system, so it really does need a diagnostic to obtain the fault codes, then pope them up here with your VIN for help - and don't get under the vehicle unless it is independently supported - the suspension can lower instantly without warning crushing you when there is any issue with the system.
