Buzzing ignition
JackTar
Buzzing ignition
Unread post by JackTar »
Several times in the last few days there has been a buzzing noise when I turn on the ignition. Is it anything to worry about ?
The car is an XM 2.0 turbo.
Stuart McB
Unread post by Stuart McB »
I'd take off the stering cowling and just double check that the main power leads are all ok and that there is no arching across the wiring. Had simalar on a Seat lighting switch, the whole car nearly went up in flames.
JackTar
Thanks Stuart, I'll check that out.
