How to to remove engine rocker cover on 2014 Citroen Relay?
Probably the most n00b question of the day. Anybody know the easiest way to remove the engine rocker cover on a 2014 Citroen Relay under the bonnet? I'm trying to inspect the injectors. I can remove the cover from it's fixings, it's loose, but I can't figure out how to actually lift it from the bonnet as there are so many obstructions? Thanks!
