Trailered home yesterday after the clutch went tio the floor and stayed there -- much unhappy as I did the lot just 8k miles ago. On inspection, turns out the hydtraulic feed pipe has popped out to the bleed position as one or both of the slide in clips must have let go. According to Citroen, these are not avcailable loose, only as part of the ludicrously expensive pipe assy.
Just wondered if anyone has found a source for them, or any generic clips to do the job ?
Mike.
C4 B78 2.0 Blue Hdi, Clutch hose retaining clips
onthecut
- x 7
PaulC5
- x 698
Re: C4 B78 2.0 Blue Hdi, Clutch hose retaining clips
The clips seem to come with a slave cylinder, as an example https://www.ebay.co.uk/itm/295267463992
onthecut
- x 7
Thanks Paul.
I know -- it makes it an expensive clip ! Got lucky however; local indy clutch fitter had a box full of removed bits and a clip off some Renault was just the ticket.
Mike.
Mike.
