Asking for help, before I cause harm to myself.
The 2005 C3 1.4HDI that I purchased had its airbags deployed ( steering wheel and passenger) , I will transfer the airbags from the donor.
My question is, where are the crash sensors located if any. I have replaced the engine wiring and didn't see anything.
I'm worried that when I connect everything and start the car the airbags will deploy.
Any pointers on how to test the system?
Airbags for MK1 C3
- x 1061
Re: Airbags for MK1 C3
The crash sensors are inside the actual airbag ECU. This will need to be replaced or reset.
esajoda
Thanks Wheeler, so if I replace the airbag ECU behind the gear lever I should be safe?
- x 1061
Yes.esajoda wrote: 16 Mar 2024, 19:29 Thanks Wheeler, so if I replace the airbag ECU behind the gear lever I should be safe?
Even if you were to install new airbags without changing the ECU it would not deploy the airbags. you would just get airbag errors & the airbags would not deploy. once the ECU deploys the airbags it gets 'locked'
