Diagbox 8.55 reports
mitsub
Unread post by mitsub »
I've been using 7.62 over the last 10 months no problems but I have now changed laptop (64 bit) Surface and installed 8.55 via VMware.
No problems in operation just there is no tab for REPORTS. Any ideas?
x 6945
Re: Diagbox 8.55 reports
Not sure why you upgraded to that version for your X7. You should of stuck to 7.62, Later versions start removing features like telecoding, but still covers vehicles up to January 2015.
mitsub
Could anyone show me a screen shot of 8.55, main page with Citroen or Peugeot car choice open.
x 6945
There are lots of issues with that version - which is why I suggested you stick to 7.62.
cit-rotti
x 77
Unread post by cit-rotti »
There are many offline versions - even under 9.xx, which do not display all tabs - this tab is not required for diagnostics.
Updates to DIAGBOX 8.xx are usually patched under DB 7 and are not always complete in the AW root area.
As recommended, 7.57 or 7.62 should be used for vehicles up to 2015.
For newer vehicles then DB 9.xxx
Greetings Wolfgang
mitsub
Thanks Wolfgang and Marc, I understand more now.
