Boxer heater/coolant problem
KarlDilkington
Unread post by KarlDilkington »
Please can anyone help?
I have a 2018 Boxer which has had a problem about an year ago, the temperature gauge was up and down, coolant was leaking and the heater didn’t blow hot.
My garage, who have been very good before, replaced the water pump and all was fine.
A couple of months ago the coolant started leaking again and the heater stopped blowing hot. The temperature was ok.
Took it back to the same garage, they replaced the EGR housing (at great expense!) and it was ok for 4/6 weeks.
Back to the garage,they now suggest replacing the engine- £8k!
HELP!
Huskyxantia
x 908
Re: Boxer heater/coolant problem
Unread post by Huskyxantia »
Wheres the leak location ? Have you had a look under the engine ?
:-D
Huskyxantia
x 908
Also what engine have you got ?
:-D
Huskyxantia
x 908
Oil filter coolant housings can leak, if that helps
:-D
