Hi all
I have a 1.6 BlueHDi Elegance 3d 2016, I helped a colleague charge his battery, all of a sudden my car stopped completely, and wouldn't start again. Some lights come on. But all i get is a clunking noise, a mechanic came out and said it had ground to earth or something like that. When we charged battery all cables were on correctly.
Any help would be appreciated
Ds3 electrical problems
- x 6950
Re: Ds3 electrical problems
Sounds like you haven't connected them up correctly and blown a fuse.
Welshspider
We made sure that they were connected properly before we started.
- x 6950
I only say this as some PSA cars have an inaccessible negative, so there is an earthing point specified in the engine bay to use and further, sometimes the battery terminal is not marked as red....
Welshspider
OK is it best to replace all the fuses then
- x 6950
Well I'd certainly start testing them - at the engine fuse box to start with to see if there's any obvious ones that have blown.
Welshspider
All sorted now was the ecu blown
Won't be doing that again lol
