Can someone please tell me, what's the throttle control body's wiring/connector diagram. How can I measure signals coming from TCU to ECU?
I have C5 X7 thp156, 2014 which gives DTC-codes: U1208, P061F, P2101 and P3010. These codes have been read by iCarsoft V2.0.
Br.
Jaaskaa
C5 X7 THP156 1.6 Petrol Throttle control body
Jaaskaa
Re: C5 X7 THP156 1.6 Petrol Throttle control body
Forgot to tell that when I start the engine and let it run idle, car goes to a limp-mode and radiator cooling fan start to run in full speed. It behaves like this even if outside temperature is way below 0 degrees.
I have already changed the MAP-sensor (the upper one in Intake air manifold), since that was easy and quite cheap to do but it didn't fix the fault.
Br.
Jaaskaa
Br.
Jaaskaa
Jaanne
Hello, Do you find solution? Missä oli vika? (Translated: What was wrong?)
Reason: Added translation
- x 8085
Please only post entirely in English to ensure the moderators do not disapprove your post.
Jaaskaa
It was throttle control body that caused this problem. Bought new one and installed it; car started to act like it should.Jaanne wrote: 04 Jan 2026, 17:55 Hello, Do you find solution? Missä oli vika? (Translated: What was wrong?)
