Peugeot 207 Error Codes - P2426 & P0031
BigBrows
Unread post by BigBrows »
Hello
I have recently just replaced the Engine Bay Fusebox 9667199780 on 207 sw due to water ingress on middle brown connector
When using tool now I have the below faults
P2426 - Exhaust Gas Recirc Valve (EGR)
P0031 - Oxygen Sensor Heater (Bank 1 Sensor 1)
When replacing fusebox I had to splice the cables to allow connection in doing this I am thinking that one maybe two might not be making full contact hence the reason for the fault
Can the pin out from this connector be verified
x 6946
Re: Peugeot 207 Error Codes - P2426 & P0031
We'll need the VIN
BigBrows
Many thanks
That's the VIN code there
