Info needed on a C5 Aircross Hybrid
Steve Walsh
x 518
Unread post by Steve Walsh »
Hi All
A friend of mine, she has a 3008 Peugeot ,1 of the cars I seem to be responsible for. It has the 1.2 Puretech and is now on its 2nd belt courtesy of Peugeot.
At the moment the belt seems to be ok, but is using quite a lot of oil, No leaks and doesnt smoke, so guessing cat is catching whatever it is burning.
She has lost faith in the car, and so have I.... She is now looking at a C5 Aircross Hybrid, We looked at one yesterday and when I opened the bonnet there was another Puretech engine, a 1.6 Turbo. VIN: VR7**************[VIN obfuscated, can be read by forum staff] . Is this going to have the same belt issues?... It 1s a 2010 car with around 48000km 29000 miles.
Thanx for any advice
Steve
x 6946
Re: Info needed on a C5 Aircross Hybrid
Hi Steve
No need to panic, this is not the same engine as the 3 Cylinder EB2 1.2. This has the EP6FADTXHP engine which is a 4 Cylinder and has a timing chain, not a belt.
Steve Walsh
x 518
That is great news Marc, Considering I don't spanner for a living anymore, I seem to be busy with friends and relatives cars and don't want one of them buying me more work.
Thanx very much
Steve
PaulC5
x 698
Unread post by PaulC5 »
I would check if the timing chain has been replaced since they can wear at low mileages if it is a vti engine. We had a 1.4 vti and that needed a new one at about 50k miles. It also used oil from when we got it on 12k miles.
I have found the Citroen diesels to be reliable so do not discount these.
x 6946
This has a timing chain, not a belt Paul - so has no scheduled replacement and should outlast the engine.
x 1496
Isn't the 1.6 the Prince engine as used in the Mini, I suggest you google it, and make an informed choice :shock:
x 6946
Of course, this is a variant of the Prince engine and I make no claims as to the reliability of the engine itself as Richard intimated :wink:
x 1472
Unread post by xantia_v6 »
Since about 2012 (coincidentally when BMW stopped using them), the reliability of the timing gear was improved to acceptable levels.
I would still not call them a great engine, there are too many plastic components that crack or distort with age, causing coolant and oil leaks.
