C5 2010 maybe limp mode
Mark 2Chevrons
My c5 hdi 2010 has no acceleration like it is in limp mode have checked pedal and throttle valves,all seems ok. My mechanic said there are a few error codes coming up,he thinks it may be turbo actuators- Any ideas?
- x 6950
Re: C5 2010 maybe limp mode
No without the fault codes!
Stick them up here with your VIN if you want some help.
Mark 2Chevrons
Thank for your reply ,we scan it today and came up with these codes- P2566 - P1446 -P0610 ,these are coming up as Permanent faults
P024B-P149A-P1498-P0098-P024E are Intermittent. Vin No. VF7**************[VIN obfuscated, can be read by forum staff], If you could help and give me some ideas that will be greatly appreciated.Mark
Mark 2Chevrons
Also a Citroen mechanic that is a long way from me said to check vacuum lines to the turbo,as this can often be an issue. could this be worth looking at?
