Would anyone have the circuit diagram for the control of this flap. It is the slide button type control mounted above the radio. I have the controlling motor removed and it seems to have no faults. The internal gears are ok and on full heat the ac pump turns off ok. I think the problem may be in the dash control unit. I am testing low and varying outages coming from it as I slide the controller button. Any help appreciated.
405 series two air conditioning hot-cold air flap circuit fiagram
Prrrgo
Bonjouir from downunder.
Prrrgo
