Hello,
I had a P11A3 fault code (i put up a post a few days ago) and it disappeared after replacing the VVT solenoid (stupid engineers, took me hours...) but this P0010 code popped up (and "check engine" light is on - i can't earse the fault, it is defined as "permanent").
The car seems to run fine , maybe even better than before and i also think that cold starts are quieter.
As the pics from my last post show, the timing chain's tension seems ok.
In my PSA service box, the p0010 wording is different...
In the programmable section of the service box i reprogrammed the dephaser option, the "check engine" light went off but appeared again this morning
Does anyone have a clue?
