EGR loom where is other end?
MichalW
Unread post by MichalW »
Year 2011, Peugeot 3008 1.6 HDI
VIN VF3**************[VIN obfuscated, can be read by forum staff]
After EGR replacement shows error os disconnection P0405 incorrect position open circuit or short circuit to earth. Had suspicion to it before now look during replacement just got disconnected or it loose cable.
Anybody can point me where to search second end. Loom part number or photo would be great 😃
x 6948
Re: EGR loom where is other end?
This is the EGR (1297) connection on your vehicle to the Engine ECU (1320):
MichalW
Thanks a lot EGR have 5 wires right section of 1297 square what are those 3 wires from left 3V BE ? Bypass?
x 6948
1475A: EGR BYPASS position repeat sensor signal output
1474A: EGR valve BYPASS position repeat sensor earth
13C3D: supply +5V CM VCC4
MichalW
Brilliant thanks 👍
