Hello,
I'm new here, hello everyone, please give me some advice.
The C5 Cross Tourer has a 15mm higher chassis than the "standard" C5. What is its reference height? Front 160, rear 106 or 15mm must be included. (160-15, 106-15)
thank you
Excuse my English, translator..
C5 Cross Tourer suspension reference height.
- x 6946
Re: C5 Cross Tourer suspension reference height.
There is no additional documentation concerning the specific height references for the Cross Tourer that I can see. Only the 4cylinder and 6 cylinder engines differ in the documentation.
Diagbox should be able to provide you with the pre-programmed reference heights, so you should be able to use this to see what the expected range is.
maba57
Thank you for your response. I don't have Diagbox. I'll try to ask someone.
maba57
Find reference suspension heights for the C5 Cross Tourer. It is 155mm at the front and 91mm at the back. The document is in Russian, a language that is not very popular now, I could not translate it automatically.
It's OK at the front, +27mm at the back. I have to adjust it, I expect a more comfortable ride.
I am attaching the document, maybe it will help someone.
If I have misplaced the document, C5 Cross Tourer suspension reference height. correct it.
- Attachments
[The extension zip has been deactivated and can no longer be displayed.]
