Air-con fault could it be..
tomsheppard
Unread post by tomsheppard »
The fans come on so the switch is fine. The compressor relay is fed from the same place as the fan but in series with the pressure switch (to earth), giving a 99% certainty that you are low on gas!
edd001
Unread post by edd001 »
most main dealers should do it.
if the switch is dim when turned on i would be looking at a seized compressor so make sure they have a look when you get it done.
andycarter
Unread post by andycarter »
The switch may be dim just because the lamp inside it is knackered.
Hint: the green lamp is the same as fitted inside the alarm cancel button - much more easy to find at scrap yards
