Citroen xsara picasso sill thickness
Moc
Hi I need to patch up the sills on the picasso would 1.5mm sheet be ok.
OnlinePaulC5
- x 705
Re: Citroen xsara picasso sill thickness
I would think it should be ok and may be thicker than the existing steel, it will also be thicker than the rust you are replacing. You can see what thickness of steel has been used if you look at the edges of the sill, along the top would need the door seal lifting.
Moc
Yes good idea Paul.
