Diesel spill under fuel filter 1.6HDi
xsara92
x 3
Unread post by xsara92 »
I have made a silly mistake with my Xsara 1.6 HDi.
Long story short, most of the diesel in the fuel filter (less than 1/5 litre) leaked directly down onto the parts installed beneath it. I had failed to notice that the rubber drain pipe was missing, that would have directed the diesel down towards the floor, where I had a catch tray waiting :oops: I actually believed the drain pipe was one of the other tubes connected to the filter
Most of the diesel seems to have collected in a metal strut / bracket several inches below, but there are too many actual parts in the way of it to see for sure.
The fuel supply and return hoses (one of them) caught a bit of the leak too.
Does anyone know if there are any parts under the filter which will be critical to clean later?
2008 Xsara Picasso btw
Stewart(oily)
x 35
Re: Diesel spill under fuel filter 1.6HDi
Unread post by Stewart(oily) »
Unless it has found its way into the clutch which is unlikely there is not much harm it can do, I would dribble some washing up liquid down into the area and follow it with a watering can full of hot water and not worry too much.
xsara92
x 3
Thank you Stewart
