I have a feeling something has broken in the rear electric motor.
I was reversing into my driveway when suddenly the car started emitting very loud grinding noise from the rear.
When put in to neutral no issue, but as soon as a forward or reverse is engaged and throttle is applied, the car barely moves. Sound from rear is very loud.
It will be towed to a garage, but perhaps anyone knows what could be the issue?
DS5 Hybrid 2.0 grinding noises from rear
StrictlyConfidential
- x 5
- x 6954
Re: DS5 Hybrid 2.0 grinding noises from rear
Hard to tell if this is part of the transmission reducer (if it has a bearing noise) which is part of the electric motor sub-assembly or something else to do with the piloted gearbox....
Only a proper look will determine the problem, but fingers crossed it's not the electronic reduction gear, as that's a tad under £2.2k
