New member
the2ems
- x 10
New member
Hi. I am in the process of changing vehicles, from C3 Aircross to C4 C series. Is there a section of the forum specifically for C4 please.
CITROEN C4 1.2 PURETECH C-SERIES EDITION S/S 5DR (2023)
- x 5674
Re: New member
Welcome!
No, sorry, there is no dedicated C4 space, all just in the general Citroen forum.
You could try doing a forum search for C4 and possibly narrow the search terms if there is too much there to wade through.
- x 6946
Re: New member
Hi and welcome.
the2ems
- x 10
Jay-Bruce
- x 280
Re: New member
Hi, and welcome aboard...
I believe we keep all the Citroen models together in a general citroen forum, and indeed all three french marques in their own forum, but don't seggragate them into model specific sub forums because a lot of these cars have interchangeable parts, so often times owners of different models can share their experiences. Lets take the Citroen, and also Peugeot, 2.0hdi engine as an example, which I believe was used in C3, C4 & C5 models, so if you had a problem with your C4 throwing a fault code, if your thread was in a C4 subforum, a C5 owning forum member who had been through this same issue might not see your plight, and thus not answer. But since the forums structured with all citroen models in the Citroen Subforum, the same C5 woner might recognise the symptoms in your thread title about your C4, and tell you what fixed that issue on his car, with the same engine.
