Citroen relay 2010, started normally but when to her the other day ignition on, all dash lights , pre heat went out turned key and nothing.
Checked all fuses and are OK.
Turn headlights on and turned key and headlights stayed the same so battery ok.
Does anyone know if the relay van has a starter relayand if so where would I find it as I've been looking but no luck .
Cheers
ice22
