RT3 no cd option available in source
This is the RT3 unit and was made by Magneti Marelli
The RT3 was available in a few different hardware versions, the later ones supporting MP3 playback. These units had an optical connection to the Display Screen.
LanciaPhedra2004
Unread post by LanciaPhedra2004 »
Helo,
I have already written a message on language change topic, I couldn’t get cd to work and waited for the new unit to arrive but I encountered problem.
The cd unit seems to have different cable with less pin and unfortunately I am shipping back.
However, I would like to notice that strange behavior.
When you insert cd it gets in, but it does not attempt to spin at all. In fact, there is no cd option in the Source menu, only radio and that’s it.
How would you attempt to diagnose the actual problem to solve it?
Thank in advance for any advice.
x 6945
Re: RT3 no cd option available in source
You would need a diagnostic to be done on it, but from the sounds of it the CD unit has died. Bear in mind these units are 20 years old + now.....
LanciaPhedra2004
I managed to get an other rt3 unit. I swapped cd part and put the whole thing back into car. Cd started working, everything looked fine. I took the key out and turned back on again. Now screen shows logo for few seconds and orange light is on. Then it reboots and tries again.
What’s wrong now?
x 6945
Hard to say on a Forum without you getting it properly diagnosed. On a PSA vehicle, Lexia should be able to interrogate the unit to see if there are any issues being reported, but with your Lancia, I can't advise.
LanciaPhedra2004
Success!
The unit woke up again and everything works. I believe there was connection problem between head and body units. When I plugged all connectors, the fans were on but no screen and no lights. I played a bit with front part and it turned on
LanciaPhedra2004
And one more question, do you know whether I could add Bluetooth to this rt3 so I could stream music from iPhone?
x 6945
No, not possible. Far too early for Bluetooth.
You'll have to use a third party device that can transmit Bluetooth via an FM radio signal that your RT3 will be able to play on a certain frequency. But you will have to use the after-market device to control tracks. Only the volume will work on the vehicle controls.
Or you can create an MP3 CD which is usually big enough to store about 100 tracks on depending on track size.
deniz arda
Unread post by deniz arda »
Hello i cant find the actual topic but i think this can be match to. I have a RT3 navidrive system and it doesn't have bluetooth. I found bluetooth module for rd4 system and I checked the sockets and the pins and cables were match. But I don't know how can I connect the original mic to this bluetooth module it has 3.5mm jack enter but i can't find the mic cables in my radio controller. Thanks!
x 6945
You can’t!
You will need to buy a separate microphone and install it directly. The factory fitted microphone is integrated into the vehicle's wiring harness and cable ribbon.
deniz arda
Thanks!
