Re: Park Assist Queries
berberz
Unread post by berberz »
Hello @GiveMeABrake
I have C4 Shine 2023 model car and i have few questions can you help me?
1- where can i check/download latest firmware for citroen cars?
2- where can i download legal software update tool for PC/Mac
3- is Restore and firmware update procedure different?
thanks
Reason: Created new thread
berberz
Park Assist Queries
is citroen use same firmware globally? for example uk and fr
I ask because some options are disabled in my car for example wifi and park assist.
If i download firmware from different country can i use these features? or Citroen make firmware for based on VIN?
x 6946
No you don't seem to understand what firmware is.
Firmware is a software update to a specific piece of hardware to fix bugs and in the case of Head Units, to update Bluetooth compatibility for later phones on the market. They do not add vehicle options like WiFi and Park Assist! These items are pieces of hardware and systems fitted to the car if specified when new or if part of standard equipment - you cannot just 'activate' them magically. If your car does not have park assist or on board WiFi then you cannot activate these with software - as the systems are not present.
Firmware is the same globally, although not all Head Units for example are available in all countries or may be modified for local laws.
berberz
GiveMeABreak wrote: 08 Feb 2024, 10:47 No you don't seem to understand what firmware is.
For example Part Assist exist in C4 Shine 2023 model (country based) but i dont have it.
Citroen service say it is not enabled at moment maybe new updates with come this option.
Wifi is disabled by default in our country (compliance issue) when i try enable it wifi search screen freeze
Note: I found youtube videos some services install new firmware and they can use park assit
shortly custom firmware fix some disabilities for exist hardware
x 6946
berberz wrote: 08 Feb 2024, 14:22 For example Part Assist exist in C4 Shine 2023 model (country based) but i dont have it.
If you don't have the reversing camera, front and rear parking assistance hardware, the correct Park Assist ECU and everything else, then no software in the world will make it happen.
berberz
GiveMeABreak wrote: 08 Feb 2024, 16:21
I got reverse camera
x 6946
Re: Re: Park Assist Queries
I've moved these posts into a new thread as they are not relevant to the touchscreen update firmware.
You may have a reverse camera, but the system uses other hardware too. You need to have the front and rear parking sensors AND the lateral Blind Spot monitoring sensors in addition for this to work as well as the correct configuration and compatible hardware.
