I just purchased new front spheres for my 1997 Xantia V6 Activa : I checked the pressures they came with : 700 PSI / 48 BAR . What are the correct pressures for my Xantia?
I have found a page in french that shows 40/45 BAR but what does that really mean? and then there are 2 numbers beside that :+5 and below that -20 and below that 0.7 in red. I have no idea what the 0.7 in red means.
It seems that 45 + 5 = 50 BARS = 725 PSI.
Furthermore, it seems that 40-20 =20 BAR ?? But that pressure seems too low : so I don't really understand all these numbers.
My last question is that this Citroen diagram shows "montage d"origine" and then " MONTAGE MULTICOUCHES" beside that : I have never seen for sale the multilayered (Multicouches) spheres available anywhere for the Xantia. Are the "MULTICOUCHES" SPHERES available anywhere .
And IF anyone has used the "MULTICOUCHES" SPHERES, what differences in ride and longevity was experienced?
Thank you in advance ...
checking Xantia Sphere pressures
- x 1460
Re: checking Xantia Sphere pressures
The Series 1 V6 hydractive should have (450/45/0.7) front corner spheres: 450 CC, 45 bar, 0.7 mm bypass hole. I believe that the Activa spheres had the same specification.
Multicouche spheres (if you can find them) have much longer life. I have used them up to 20 years, the ones currently on my XM are about 15 years old and still giving a good ride. When they do go, they go suddenly with a split diaphragm.
Citroen were still supplying multicouche spheres about 5 years ago, but I don't think that is currently true.
For reference the original part numbers are given:
JohnM52 wrote: 07 Jun 2004, 01:17 Hi,
I have listed both the specific part number for the V6 and haev then checked the Cit listing for all other Xantia spheres ( Series 1 only)
having checked the specific part no for V6, I get:
front sphere 5271 76
on checking the listed Xantia spheres:
95 666 857 SPHERE + GASKET
- ESTATE AND WITHOUT HYDRACTIVE SUSPENSION
5271 76 SPHERE + GASKET
- ESTATE AND HYDRACTIVE SUSPENSION
- SALOON AND HYDRACTIVE SUSPENSION AND W/O ACTIVE ANTI-ROLL
5271 C7 SPHERE + GASKET
- SALOON AND HYDRACTIVE SUSPENSION AND WITH ACTIVE ANTI-ROLL
rear sphere for V6 5272 36
listed spheres for Xantia
5272 34 SPHERE + GASKET
- SALOON AND WITHOUT HYDRACTIVE SUSPENSION AND TEMPERATE COUNTRIES
- SALOON AND WITHOUT HYDRACTIVE SUSPENSION AND COLD COUNTRIES
5272 40 SPHERE + GASKET
- ESTATE AND WITHOUT HYDRACTIVE SUSPENSION AND TEMPERATE COUNTRIES
- ESTATE AND WITHOUT HYDRACTIVE SUSPENSION AND COLD COUNTRIES
5272 36 SPHERE + GASKET
- SALOON AND HYDRACTIVE SUSPENSION AND W/O ACTIVE ANTI-ROLL AND TEMPERATE COUNTRIES
- SALOON AND HYDRACTIVE SUSPENSION AND W/O ACTIVE ANTI-ROLL AND COLD COUNTRIES
5272 38 SPHERE + GASKET
- ESTATE AND HYDRACTIVE SUSPENSION AND TEMPERATE COUNTRIES
- ESTATE AND HYDRACTIVE SUSPENSION AND COLD COUNTRIES
5272 42 SPHERE + GASKET
- HYDRACTIVE SUSPENSION AND WITH ACTIVE ANTI-ROLL
Front Hydroactive for V6 5276 09
listed Xantia hydroactive front up to RP 6778
75 520 295 REGULATOR SPHER
- HYDRACTIVE SUSPENSION AND W/O ACTIVE ANTI-ROLL AND TEMPERATE COUNTRIES
- HYDRACTIVE SUSPENSION AND W/O ACTIVE ANTI-ROLL AND COLD COUNTRIES
95 669 124 REGULATOR SPHER
- HYDRACTIVE SUSPENSION AND VERY COLD COUNTRIES
- HYDRACTIVE SUSPENSION AND HOT COUNTRIES
listed Xantia hydroactive front SINCE RPO No. 06779 EXCEPT HP20 (AG)
- W/O ACTIVE ANTI-ROLL
5276 09 REGULATOR SPHER
- WITH ACTIVE ANTI-ROLL
listed Xantia hydroactive front for HP20 AutoGearbox
- INJECTION ES9J4 AND HP20 (AG)
Rear Hydroactive for V6 96 045 530
listed for Xantia hydroactive rear up to RP6778
96 045 530 REGULATOR SPHER
5276 06 REGULATOR SPHER
listed Xantia hydroactive rear SINCE RPO No. 06779 EXCEPT HP20 (AG)
listed Xantia hydroactive rear for HP20 AutoGearbox
The Main Accumulator sphere is (as expected) the same for all Xantia - 95 666 763
THe anti sink is listed for all as 5293 03
Hope this is of some use
JohnM
