Is there any possibility to hide both features; Active Safety Brake and Blind Spot Sensors of a Peugeot 3008 GT-Line 2018 model.
The mirrors are having Blind spot icons at the edges but they are not working and not showing in the i-cockpit.
Also Active brake is not working.
Under Setting and Tools- System Information - System version is 074C.
Any possibility to change the firmware to reactivate above missing features.
Thanks.
Blind Spot Sensor & Active Saftey Brake Hidden
ishantha
Reason: Moved to Peugeot Forum
- x 6957
Re: Blind Spot Sensor & Active Saftey Brake Hidden
Active Safety Brake: Deactivate it from the Touchscreen menu (but you will have to do this every time your start the engine) - after all it's a safety feature.
The same for Blind spot monitoring - these can be deactivated from the touchscreen menu.
As far as I know the blind spot system does not show anything in the i-cockpit - only the diodes in the mirrors on the affected side.
Your last question doesn't make sense! You are asking to deactivate these features in the first part of your post and then asking to reactivate them...
