Hello.
I was thinking of installing 2 LEDs inside the car, that indicate the 1st and the 2nd speed of the radiator cooling fans. Is there anyone that can help me by telling me to which relay pins I have to take a 12v signal , for each fan speed, from the relays that are installed in the triangle relay box?? If possible , I prefer , at the slow fan speed to turn on the one LED and at the high fan speed to turn on both of the LEDs, if possible.
The LEDs are already installed , so the only thing is to figure out in which +12v to connect the 2 signals.
Thank you in advance!!
Xantia 2 - Cooling Fans Relays Help
- x 8422
Re: Xantia 2 - Cooling Fans Relays Help
A search of the forum will soon unearth the required wiring diagrams
thorter
- x 44
Here is a de-tangled diagram that may help. You still need to work out which wires are which on the car.
Clogzz
- x 40
- x 8422
Excellent
Good to see you
