C5 X7 Heater / cooling fan makes intermittent, intense noise
Gastomato
x 3
Unread post by Gastomato »
Hallo all! :)
After hitting a nasty, unavoidable pothole - the heater fan in my C5 X7 suddenly began making a grinding metallic noise. It dissipates when i turn the fan speed up, then comes back again after i lower the fan speed. It does not sound good at all, and I am worried the fan needs to be changed.
Are there any recommended brands specifically that is recommended? I see there is some Nissens and others fan units that is not too costly.
Is changing the heater unit a complicated affair? I have changed one in my daughters Golf, and it was not too demanding- even for me! :-D
The VIN no for my car is VF7**************[VIN obfuscated, can be read by forum staff]
Cheers!
-Idar
x 6947
Re: C5 X7 Heater / cooling fan makes intermittent, intense noise
Hi Idar
I'll put a guide up for you in the resources section for changing this on your X7.
Link:
C5 X7 Removing - Refitting Passenger Compartment Air Blower
Gastomato
x 3
Thanks so much!
Titiune
Unread post by Titiune »
GiveMeABreak wrote: 24 Jan 2024, 12:50 Hi Idar
Link:
Hello,
Is there a way for me to read this too?
It says that I'm not authorized
PaulC5
x 701
Unread post by PaulC5 »
To see some of the forum content you have to make a donation donate
x 1943
Unread post by Paul-R »
Just hold on that for moment while I try to find out what the current situation is given that we can't access the Stellantis parts database. You may still have to donate as the information in the restricted area will have been garnered when we did have access to the database and will have paid for it.
x 1943
Yes, as I thought, a donation is still required for access to the information there. £10 minimum or equivalent in your local currency. Payable through PayPal.
Titiune
Paul-R wrote: 04 Jul 2025, 14:09 Yes, as I thought, a donation is still required for access to the information there. £10 minimum or equivalent in your local currency. Payable through PayPal.
Thank you very much. I made the donation, now I can access it.
Cheers :)
