ESP abs Peugeot 1007
georgejung
Unread post by georgejung »
hey
i have peugeot 1007 , i have problem with ESP... first on car start to come Abs and esp light ... i put on diagnostics and the error was c1380 pump abs.
abs esp lights was on some times and go off ... and after that was all time on... i check cable.. fuses all ok... i change the abs pump ...
and now just the esp light is lighting On ( esp error msg)
when i put on diagnostics is u1109 and u1309 ... the abs pump its the same like old one same numbers... i check fuse box in engine ,everything is perfekt ...
if any one have same problem or know to help :)
p.s the car is manual ,not automatic
tnx
Huskyxantia
x 875
Re: ESP abs Peugeot 1007
Unread post by Huskyxantia »
Id next test the ans sensors , resistance test , check youtube theres lots of videos about how to do this.
:-D
