Citroen C3 Picasso 2014
Coff9
Unread post by Coff9 »
My Citroen C3 Picasso 2014 selection 1.6 HDI .
The horn has stopped working, checked fuse in engine compartment and it is fine , any ideas as to what it may be ?
Only recently bought this car and looking at service history it looks like the horn has failed a couple of times at MOT's ?
x 8331
Re: Citroen C3 Picasso 2014
Is this the reason you want to remove the front bumper as per your other post?
If so, a good call. Check the connections to the horn and also, you can test the horn independently whilst you're there. Also, by substituting the horn for a bulb you can test the wiring and basic functionality of the horn control circuitry.
If the horn has a history of failing, it may be best to replace it.
Coff9
Yes, I need to get at the horn and test, but not 100% how to remove the front bumper to be honest
