When i go over a bump it seems to bounce all over rather than a smooth bump. The slightest small hole in the road and it handles it worse than normal spring cars.
Sometimes putting it into the 3rd up height setting then putting it back into drive just as the front raises a bit makes the ride a lot more comfortable. Also moving the steering from full lock right to full lock left a few times makes the front height go up and the ride is once again better, but the steering makes a really loud noise like a steam train when on full lock, is this normal?
Its a 2.0i, and when in the 65-80 zone the car shakes a lot. You can feel it through the floor,gear stick, steering and clutch pedal really badly. If i do the same speed in 4th instead of 5th gear the shaking is not as much. The wheels have been balanced twice in the last 2 months, each time the shaking no where near as bad (but still noticable) for a few days after the balancing, but it gets back to the bad shaking after a week or 2. Could it be the clutch causing this? [:I] [?] As i cannot get it into reverse without putting into 1st first, and gear change is very very bad as it has a EXTREAMLY heavy clutch.
The citroen garage say its the heaviest clutch they have ever seen in a xantia. Its going back in tommorow for a Clutch cable change, as it went a few months ago, and the cable we bought was a ****ty one, and should have the citroen recommend cable in. This could be causing the heavy clutch i was told, but if its still heavy afterwards they its a new clutch job
Any advise, thoughts?
Is it really that hard to have a decent ride in a citroen with the hydrolic suspention? My BX before this had very worn front stuts and other things, so i hardly ever got a good ride out of that (but was great when i did) and the Xantia was so smooth when i first got it, but did not take long for that to go uncomfortable
