Instrument panel Leds going blank
Moc
Unread post by Moc »
The leds for the speed numbers are blank at the top, so a 0 now looks like a U could this be repaired. I have changed all the bulbs in the instrument panel. Would a second hand instrument panel work ok for a year 2000 Citroen xsara picasso 2HDI
My panel has the 2 socket plug connections.
x 1061
Re: Instrument panel Leds going blank
Unread post by wheeler »
If you get a used panel off a car same age & spec it will work fine however if the ‘new’ panel has a higher mileage your car will permanently inherit the higher miles.
After late 2001 the panels are different & have a single plug.
Moc
Thanks for the quick reply
