Fuse box
Kepudon
Fuse box
Unread post by Kepudon »
Hello and thank you for accepting me. I have a 2016 c4 grand Picasso exclusive + 1.6bluehdi, can the main under bonnet fusebox be changed without the need for reprogramming,??. I think some damp might have got in mine and if I can’t dry it out I might have to renew it, hence the question. Many thanks.
x 6950
Re: Fuse box
It depends on the exact nature of the vehicle you have. Some do and some do not. If you provide your VIN I can see if you have the type that does. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Kepudon
Re: Fuse box
Vin num,… VF7**************[VIN obfuscated, can be read by forum staff]
x 6950
Re: Fuse box
Ok, so confirmed you have an engine fuse box that needs to be configured on your vehicle if replaced. It has things like the engine Supply, heating/ventilation, Lighting - signalling, Engine compartment, Visibility, and others.
Also, being that this is a 2016 model, it will need to be configured on-line, so you won't be able to use Diagbox offline to do it most likely.
Kepudon
Re: Fuse box
Right I don’t have digibox, I have the topdon bt800, so have to check that out, but first need to see if it can be cleaned at all and check the wiring around the battery, and clean the BP fuse box. Fingers crossed. Thank you.
