Peugeot 1007 engine and gearbox
Clum_
Unread post by Clum_ »
Hello all, I've got a 1007 1.6sport and I'm fed up with the gearbox faults, so my question is thus. The version of 1007 I've got is the tu5jp4 nfu wich I think is a common engine amongst psa. I was thinking a box from c2 or 206 or similar but not sure if they bolt up, also has the 1.6 and 1.4 variants use the same Box or not?
Cheers for any help.
ozvtr
x 253
Re: Peugeot 1007 engine and gearbox
Unread post by ozvtr »
The 1007 is virtually identical to the Citroen C2 and C3 platforms.
The 1007 Sensodrive has a modified version of the MA5 manual gearbox, so, theoretically, it could be converted back to a "manual" transmission. So there is no need to go looking for another gearbox.
IMHO your best bet it to obtain a wrecked, manual, C3 (they are more common than C2's) and start swapping bits.
This is only theoretical!!! There may be some physical differences in the chassis...but I doubt it.
You will also need access to a LEXIA scan tool, to "remove" the Sensodrive from the system.
Frankly, it would be cheaper and take less time to get the sensodrive fixed. But that's just my opinion.
Either way, good luck.
