Peugeot Boxer 2.0 HDI cam/oil pressure
Officina_mikuz
Unread post by Officina_mikuz »
VAN: Boxer 2016
ENGINE: AHP 163 HP
COMPUTER: Delphi DCM62_F
-P0520
-P0406
-P0340
-P0344
Sometimes the car starts righ, sometimes it takes a few seconds and rolling over (10sec)than starts.
With the cam sensor disconnected, it turns on immediately. It does not allow the error to be deleted.
The light for engine failure and oil pressure is on - it won't let you delete it.
On the car, we changed the oil pump, vacuum pump, EGR valve, throttle valve, dpf and catalyst, cam and oil pressure sensor, NEW ECU and engine wiring.
When the car starts it runs nice and quiet.
Has anyone already had such a case, and why does it not let the oil pressure and cam sensor error be erased independently sensors are connected or disconnected?
The data from those 2 sensors i cant read. Oil pressure its constant 0.5 bar but in reality its not, cam sensor its 0 . General shaft read rpm well.
