Hi all,
New guy here desperately looking for a solution to a repeating issue.
Car got into a limp mode. When checking codes via Diagbox noticed two errors in the Hybrid control ECU 1 occurring simultaneously. I've noticed that the ancillary belt tensioner was very wobbly so it got changed together with the belt. Hope was that the alternator had slipped thus causing the error with the hybrid train. It didn't. Today limp mode again with these two errors (listed below) popping up with same mileage.
If it helps, I often get electric mode unavailable when driving and it seems to be occurring with no noticeable pattern.
P1A79 Drive Train
Cause Local
Status Permanent fault
Vehicle mileage190480Km
Traction battery voltage218.5V
Current of the traction battery9.7A
Electromotor sub-assembly started
Characterisation of the fault Starting does not conform
U0167 Intersystems CAN
CauseDistant
StatusPermanent fault
Characterisation of the fault Absence of response to the unlocking request
Status of the ECU Unlocked
Thank you all.
Peugeot 508 Hybrid4 RXH 2012 hybrid train fault. U0167 + P1A79
impaelas
- x 3
impaelas
- x 3
Re: Peugeot 508 Hybrid4 RXH 2012 hybrid train fault. U0167 + P1A79
Bumping this up just in case someone can help. Still having issues.
- x 6957
Here's some further info on those fault codes. As you can see the reversible alternator and starter play a significant part for the first fault. However the Hybrid ECU is common to both faults, and if it id determined that this is the fault, it means a complete traction battery as the ECU is integrated and not available separately, so focus on the other suspects first in your troubleshooting.
| Fault Code: | P1A79 |
| Description of Fault: | Drive train: Starting does not conform. When there is a start up request, the reversible alternator and the starter are not operational. The following conditions have to be met: - Ignition on - Indicator lamp READY lit |
| Conditions for Fault to clear: | - |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | U0167 |
| Description of Fault: | Intersystems CAN: Absence of response to the unlocking request. No response from the built-in systems interface following an unlocking request from the hybrid control ECU 1. Conditions of activation of the diagnostics The following conditions have to be met: - Ignition on - Indicator lamp READY lit |
| Symptoms: |
| Suspect Areas: |
impaelas
- x 3
Thank you mate. I was trying to find tests in Diagbox that would help me narrow it down. Finding shops that are willing to troubleshoot this is impossible around here and Peugeot will simply want to replace everything and I only have two kidneys which I am very fond of.
I think my best bet at this point is checking the status of battery cells. They haven't been touched in 11 years and from what I am seing on later models P1A79 was resolved with replacing cooked cells. Will update when I find something. If anyone has other useful input thanks in advance.
- x 6957
You're at about the life span of the batteries IIRC, but hopefully the starter, alternator will give you some more options to check, but understandably, special training is needed when handling traction batteries, so many places currently will not be equipped or trained to deal with the risks associated with these, yet alone do any work on them...
impaelas
- x 3
Update. I did some tests time permitting and my conclusion is that while ECO drive is disabled (basically diesel engine is not switched off while electric drive is used) the error doesn't show. While city-driving with many start/stop activations eventually the error will pop up.
Am I wrong to assume starter is a likely culprit? I have ruled out alternator on account of it having to be 100% operational in either scenarios.
Thanks guys, you are a lot of help.
mr-white
There are lots of tests in duagbox
The codes your stating wouldn't put it in limp mode
That's engine ecu related
If your battery is still charging to near full capacity its OK
Have you any other codes
impaelas
- x 3
Thanks for replying.
Those were the only ones corresponding with the timestamp. The rest are minor ones such as locks etc. Additive warning (it wants a new dpf) has been there for a while.
barry1975
- New User
Hi all,
Ive a Peugeot 508 2.0 HDI Hybrid that won't select ZEV or Sport mode, but starts the engine straight away and in 4wd. The hybrid system shows on the display as working whiles driving. There is a permeant fault code U0167 inter-system Can fault. 3x Temporary fault codes U1286 Can hybrid network, U12C6 Hybrid CAN control network fault and P1AD8 Hybrid control ECU fault. Can any body please help or advise? I'm at the end of my wits end
vic678
Hello Barry, i know it's a longshot but i have the same problem now. The car starts and runs only in 4wd mode and i have U0167 and P1AD8 in HCU1.barry1975 wrote: 16 Dec 2024, 20:08 Hi all,
Ive a Peugeot 508 2.0 HDI Hybrid that won't select ZEV or Sport mode, but starts the engine straight away and in 4wd. The hybrid system shows on the display as working whiles driving. There is a permeant fault code U0167 inter-system Can fault. 3x Temporary fault codes U1286 Can hybrid network, U12C6 Hybrid CAN control network fault and P1AD8 Hybrid control ECU fault. Can any body please help or advise? I'm at the end of my wits end![]()
Although i'm happy i was able to start and make the car running after about a year of it sitting like a brick till i found the problem was a blown alternator.
So i have swapped in a working one and new 12v battery and programmed it yesterday and getting those errors now on HCU1.
There are some other faults, related to BSI and Gearbox but those were present before the car died more than a year ago because of the alternator.
