i am heading for my first go at xantia diy and spheres this weekend; the front bounces like it has no shocks and the back much too firm like its over shocked.
(i'm still puzzled as to how failing spheres can produce such contrasting symptoms)
i'm intrigued; my front spheres have the following citroen numbers which i cant find in the forum or the gsf listings; 96178589 DL
i would be dead interested if anyone has an idea what they are from
regards
xantia sphere numbers no trace so far!!!!
TheWorker
xantiav6
- x 3
The most complete Xantia sphere list I have found is at:
http://www.citroenbilten.com/forum/view ... p?tid=1402
(about 3/4 down the page). It lists this sphere for a 2.0 petrol non-hydroactive to 1996.
TheWorker
cycaduk
Just a twopenneth worth. I used to drive Bx's and found that if the rear spheres went, the trailing arm bearings died pretty soon after. I think this was because when the rear spheres failed on the BX there was no movement on the suspension system. A proper citroen expert may comment on that; I have heard that the xantia bearings are much stronger, but they may still go.
heath robinson
hi thanks for your research; good of you
i had hoped the wrong spheres were on the front and this might allow me to solve the puzzle of how failing spheres can produce such contrasting symptoms.
looks like the job may be off for the weekend as gsf don't stock the tool. anyone know if cit main dealers sell them? trying to work out how to improvise; not happy about hitting the things
let's hope the rear bearings aren't next. this is fast looking like the worst buy xantia for a while!!!
regards
regards
BigMac
Two possibilities for a sphere removal tool:
(1) contact Pleiades - theyre on the net - their tool costs about £40;
(2) make up your own tool: buy a 2 or 3-foot length of threaded rod, find a bit of metal plate approx. length diameter of a sphere plus a bit more, drill 2 holes one at each end so that rod will pass through, find 2 nuts to fit the rod, bend rod carefully into U-shape. Fit rod round the sphere, tighten plate up the rod tight against sphere ... bingo!
HTH
HTH
heath robinson
Homer
- x 16
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by heath robinson</i>
When the spheres fail completely you effectively have rock solid suspension. It would be the equivalent of replacing springs with iron rods. The result is the car bounces on the tyres (the only part with any spring), which obviously have no damping. It's the gas in the sphere which acts as a spring. The fluid entering and leaving provides the damping.
