peugeot 306 rough running
froggy
- (Donor 2026)
- x 4
Hi, my peugeot 306 is running rough when warm. when cold , it runs fine, anyone any ideas where to start? cheers Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
PaulC5
- x 699
Re: peugeot 306 rough running
You can look for anything obvious around the engine but a diagnostic is needed to check for anything else. Also provide details of your car - year, engine and if you get any fault codes the VIN will help.
froggy
- (Donor 2026)
- x 4
306 Meridian, 1.4 petrol, many thanks.
Terry
- x 8423
Terry, do indeed point a Lexia at it and do a diagnostic on the engine ECU as Paul advises..
Potential causes are a duff coolant temperature sensor or a duff oxygen sensor but without a Lexia session you're staggering around in the dark...
Has the fuel consumption significantly risen? Does the exhaust smell a bit rich and of petrol fumes?
froggy
- (Donor 2026)
- x 4
Hi Jim, yes it does smell rich, cheers Terry.
Terry
- x 8423
Give the Coolant Temperature Sensor a try Terry, they're not expensive and hopefully it'll resolve the issue.. It's my hot favourite to be the cause... (no pun intended
froggy
- (Donor 2026)
- x 4
cheers Jim
Terry
froggy
- (Donor 2026)
- x 4
there are three sensors, one blue, one green, one brown, wondering which of the three, the coolant temperature sensor is? cheers Terry.
Terry
- x 8423
The green one sir! Blue is for the gauge/overheat/engine cooked light and the brown one is the A/C Bitron Sensor...
froggy
- (Donor 2026)
- x 4
Cheers!!!!
Terry
