Evening all again.
Decided to change engine mount bushes top and bottom as steering was pulling to left and right when accelerating as if you gone down a pot hole, noticed that the bushes were badly disintegrated and they had quite a bit of play in them,so thinking it was the issue,now replaced but still seems to pull, any one had this issue or have any ideas what the problem could be.
Thanks. Eb
Steering issue
- x 8457
Re: Steering issue
My thoughts on this are in your other thread Eb...
- x 8457
Re: Steering issue
Also, don't dismiss the possibility a slightly binding brake caliper on the side it's pulling to... I've had that too...
Feel the wheels after a run. If one feels warmer than the other then that'll be it...
Big Eb
Re: Steering issue
Funny you should say that, did notice one side was rather warm,but this issue occurs when you give it a bit of Welly and it jerk's to right or left, would this be part of the same issue.
Cheers Eb
Cheers Eb
Big Eb
Re: Steering issue
Seen your other comment, thought it was removed as I put in the wrong section as couldn't see my post.
- x 8457
Re: Steering issue
Very much so, the more welly you give it the more pronounced it will be...Big Eb wrote: 02 Jan 2024, 18:07 Funny you should say that, did notice one side was rather warm,but this issue occurs when you give it a bit of Welly and it jerk's to right or left, would this be part of the same issue.
Cheers Eb
Big Eb
Re: Steering issue
Ok thanks for your input, will give it a look if not raining tomorrow.
Cheers Eb
Cheers Eb
