Which DPF fluid- Berlingo 2012
Lwalker199
Unread post by Lwalker199 »
Hi all,
Struggling a bit to find the exact PAT fluid I need for my berlingo 2012, do anyone know if this is the correct fluid?
https://www.ebay.co.uk/itm/114664905905 ... name=11051
I can confirm the connector on the tank is blue if that helps.
I was hoping to do the job myself then get it reset at a garage.
Appreciate any help! Thanks
x 1061
Re: Which DPF fluid- Berlingo 2012
Unread post by wheeler »
Most likely Eolys Powerflex additive but would need VIN or RP number to confirm.
Lwalker199
Thanks, is there somewhere I could check with the VIN?
Lwalker199
If someone can help it’s much appreciated!!
x 1061
Yes its Powerflex additive.
Lwalker199
x 1061
All i can tell you is its meant to be Powerflex, wouldn’t want to comment on aftermarket fluids. Especially when there are places like Euro Crap parts selling 1 fluid does them all.
Lwalker199
Okay thanks for your help.
