Gearbox
Morphmite
Gearbox
Unread post by Morphmite »
Hi yet again im asking for advise, i have a gp 2014 mk2. Every time i brake my gearbox jumps into neutral. The clutch doesn't slip & gear change is smooth. I do have a very small oil leak on gear box but not found it yet. Would this be due to the leak or something else...many thanks in advance
x 1504
Re: Gearbox
Manual or auto?
Morphmite
Re: Gearbox
Sorry..... auto
PaulC5
x 723
Re: Gearbox
Unread post by PaulC5 »
How many miles has it done ? I had a Saab with a manual gearbox on about 150k miles and due to bearing wear it would jump out of gear. The gearbox also whined indicating bearing wear.
Morphmite
Re: Gearbox
160k, i have no whining noise & generally the car runs well apart from when i touch the brakes it jumps into neutral even in manual mode
x 1504
Re: Gearbox
My guess would be there's an imbalance between the two sets of contacts in the brake pedal switch and /or the pressure sensor in the ABS computer - needs some diag time to have a look. Although this sort of error usually causes loads of warning lights to come on!
Morphmite
Re: Gearbox
I do get a gearbox fault come up when ignition is switched on. I took it to a local so called citroen specialist & got told it the clutch but then had a friends mechanic drive it and he said gearbox not clutch. I dont have money to put it into citroen as im on disability
Morphmite
Re: Gearbox
Going to buy a diagbox setup & see if i can sort this out + will be handy to have in future
