Upgrading radio unit what funcions are lost ?
This unit is the RD4 or RD45 system, made by Continental.
Usually standard equipment unless another system is specified as an option. There are Single & Dual Tuner versions. RD45 features over the RD4: The RD45 has USB connectivity & integrated Bluetooth module supporting Phone & Audio Streaming.
bitsas004
Unread post by bitsas004 »
Hi, so I thought of upgrading the radio but read on the forum that you can loose some steering wheel functions, is it just radio lever functions or cruise control / display lever where you can check mpg economy too ?
I have the dispatch enterprise 2014 Vin: VF7**************[VIN obfuscated, can be read by forum staff], thank you.
Reason: Moved to RD45 Forum
x 6950
Re: Upgrading radio unit what funcions are lost ?
The RD45 is not just a radio, it will provide access to some of the vehicle options. If you replace this unit with an aftermarket unit you will lose access to the options menu, possibly reversing sensor display and the trip computer and displays.
bitsas004
Would reverse still beap or would it complete stop working? as there is no display for me just sound warning when getting close to something behind, how about cruise control ? I can live without trip computer or radio button lever.
x 6950
Cruise control should not be affected. Only volume controls on the steering wheel unless you can get a compatible harness depending on what you are intending to install.
The beep sound is via the speaker in the steering wheel module, but can’t say what impact this will have, you may be ok with parking assistance.
bitsas004
Just some standard, sony or pioneer radio something like that. Ill try to dig into this a bit more see if there are any more compatible modules..
speaking if RD45 if I disconnected it and reconnect it will it ask me to code it ? if so how can i find out what the code is ?
x 6950
There is no code on these. The unit is however VIN-coded to the vehicle, so will only work properly in the same vehicle with the same VIN, so no issues about removal and refitting.
bitsas004
oh wow good to know that, was worried it needs to enter code every time when removed like on some other vans..thank you for the info
