Xantia. ABS wiring diagram/ ABS light on!
johntaylor
Unread post by johntaylor »
I need to identify which wires are coming from each wheel sensor to check them as my ABS light is continually on. I have replaced the ECU with four others from scrap yards, still on! Thanks for all responses.
Cheers
John
acrowot
Unread post by acrowot »
Hello John
What is your car? , if it is a Xantia do a search on this forum for "ABS", the pinouts have been given in previous posts.
Kowalski
Unread post by Kowalski »
http://www.andyspares.com/discussionfor ... PIC_ID=625
That post contains the pinouts. Each pin pair should have a resistance of approx 1k to 1.5k ohms. IIRC mine were around the 1150 ohm mark.
