C4 C-Series Sat Nav - Keeps loading a destination
C4OAR
- x 4
Good afternoon. Whenever I set off from home, the Sat Nav automatically assumes I want to drive to a regular destination (clever) but it's 2 miles down the road, I don't need the sat nav. I'm not sure if it's from the My Citroen app recognising it as a regular location. Either way, I'm unable to see an option to turn this off. The same for when I leave said location, it tries to get me to go home, again, helpful but I don't need it. Thank you.
- x 6950
Re: C4 C-Series Sat Nav - Keeps loading a destination
I can't see anything related to this - so either it is remembering a previous journey that was not completed fully so keeps trying to redirect you there I can't say, but it should not route you anywhere unless asked for.
Try going into your stored journey / previous destinations and remove the offending journey, or try using voice commands to "Cancel Navigation".
C4OAR
- x 4
Thank you. I’ll give that a go. I thought it was little bizarre. I’ll report back if it continues.
Sloppysod
- x 407
You may want to clear the "MyCitroen" app cache as well.
Stu
