Height Citroën C5 Cross Tourer 2.2 -2014
mvts
Unread post by mvts »
Hello,
I am the new owner of a Citroën C5 Cross Tourer 2.2 2014.
I have a question about the height of the car.
As it is a "Cross tourer", the ground clearance is 60 mm higher at speeds up to 10 km/h and 40 mm higher at speeds up to 40 km/h.
My question is if this can be turned off somewhere? So that it holds the same high as a "regular" C5?
Can it be turned off in one of the car's menus or through Diagbox?
Thanks in advance.
x 6950
Re: Height Citroën C5 Cross Tourer 2.2 -2014
No, it can't be switched or turned off. The settings are pre-configured depending on the version and the reference heights are programmed at the factory. Only minor adjustments can be made using Diagbox (after completing the comprehensive suspension height measuring procedure and making the calculations to enter into Diagbox). So I can't advise as to whether there are any other specific settings to the cross-tourer version that may affect this.
